Installed flathead screws in the RH aileron counterbalance assy as in the 3/27/12 entry.
Completed W10-03R, RH outboard rear spar attach angle, -02R outboard rear spar channel, -01R LH outboard rear spar assy. Did not attach -03R to -01R until I can check alignment using the skin as a guide. -03L had to be remade from raw stock because the holes did not align correctly. This completes sheet ONX-W10.
Started deburring and smoothing edges of the RH outboard wing ribs, sheets W22 & W23
